Hi Every one,
I would like to show you my rendering in keyshot 2024. I have a problem with the diamond, there is the metal shine inside the diamond. How we remove it and make diamond more real?
It’s hard to understand what’s the problem here. The picture is quite low res.
Make sure the metal and the rock do not intersect! the stone should marginally smaller than the ring. If the metal enters the stone, it leads to weird results. Make sur you use the KS standard diamond material, and try both render engines (interior and product). When switching to product, copy the bounce and caustic settings from the interior engine.
